Indexing adjustable cam gear
Go to solution Solved by TobyB,
6 hours ago, tme said:
You might want to start a new topic rather than posting under a thread already marked "Solved".  More likely to catch the eyes of the more experienced guys who have already commented on the original topic.
I think it is highly unlikely that the cam is causing the vacuum gauge to jump around like that.  I would be looking for vacuum leaks and adjusting the valves.  But first you might want to connect your gauge to a different vacuum source other than the booster port - think carb base or where the distributor vacuum advance connects.  I'm pretty sure the booster port has you looking at a single intake runner.  The net is full of instructions on reading a vacuum gauge that should give you other ideas.
Thanks. I have moved to “using vacuum gauge to diagnose problems” let’s continue there.
