A tiny brake/clutch fluid leak
kiva667
64026DDF-FB6D-4E00-AE62-622D4E12ABF4.thumb.jpeg.1b030311c72cb295e5ffb36c1d57795c.jpegThis has been bothering me for the last year. Every few months I have to add a tablespoon of brake fluid to the reservoir.
At first I thought the brake cylinder needed a rebuild ( I have a kit from West Germany) but then it occurred to us that the clutch slave cylinder had a leak. And as long as I am doing that, I might as well replace the clutch master  cylinder.
Am I being obsessive or is this the route to follow?
Edited by kiva667
1967 2000 #1326213 SOLD / 1972 2002 Verona - insurance loss / 1962 700 Luxus SOLD / 1975 530i Malaga SOLD
http://nk2000project.blogspot.com/
"Rust Never Sleeps"
13 hours ago, NickVyse said:
Does your NK have one reservoir for both brake and clutch? If so just replace/rebuild the clutch MC as that's obviously leaking. Or is the brake MC leaking too, can't tell from the pic?
it's a stock '67 with two reservoirs - at first I thought it was the brake MC but close examination revealed a tiny leak only from the clutch slave. I've read that replacing the clutch MC can be difficult. And the parts book has different part numbers for all of the above. Any thoughts on which slave and clutch master would be correct ?
K
Edited by kiva667
"Rust Never Sleeps"
Here is what I found :
WWW.EBAY.COM
BMW OR ATE GERMANY NEW Repair Kit Output Cylinder Clutch 1500 1600 1800 2000tilux...
WWW.EBAY.COM
Part Manufacturer: FAG. Fits Year(s):1963 - 1971. Fits car MAKE(s): BMW.
"Rust Never Sleeps"
You simply need to match what you have in the car and only you can tell us that - a lot can happen over 50 years. But you've not said why you've diagnosed the MC as faulty other than having to top up the reservoir with a teaspoon every once in a while. Could just as easily be a seeping caliper or rear wheel cylinder.
Thanks, Nick
im no mechanic but when I took the car to my guy with the repair kit for the brake MC he told specifically he traced the leak to the clutch slave. He's an old school guy whom I have learned to trust. He suggested that I change the clutch MC because in his opinion when the slave fails the MC may be close to follow.
btw he flushed the brake and clutch fluids that same day so had a good look at everthing. And he said the calipers, which I had rebuilt in 2018, were still in perfect shape.
At the same time I replaced the rear wheel cylinders, too. They are in excellent condition too, he said
Edited by kiva667
"Rust Never Sleeps"
  • 2 months later...
2 hours ago, Schnellvintage said:
It looks like the standard slave cylinder for a 2002 with a hydraulic clutch.
Matt
Thanks, Matt!  But realoem gives different part #s for the NK slave cylinders. I did find a repair kit on eBay with a similar part # but the dust cover is different, as we see in the photos already in this thread.
21521103737
The search continues.
Best,
Kit
Edited by kiva667
"Rust Never Sleeps"
It only costs $25 USD to deliver the repair kit to my door from Athens. I will buy this kit and see if it works. If it doesn't I can always try to sell it here on the forum 🙂
"Rust Never Sleeps"
  • 3 weeks later...
