Speedometer Removal question
Alex Abreu
Remove the under dash panels, if they're still in place and then you can reach up and unscrew the speedometer cable and the two thumb nuts that hold the instrument cluster in place.  You'll also need to unplug the wiring harness from the back of the cluster and the tachometer wire.  It's not hard to do.  Good luck and welcome to the forum.
  • Like 3
Kinda fiddly but not terribly difficult to remove, just harder to reinstall.
PM me for the column I did on removing and replacing the instrument cluster...
