Brake line adapter for MK4 rear conversion
rrost
The VW mk4 inlet on the caliper  is much larger than the line to the shoe system. Just looking for a way to up the size of brake line fitting.
71 itb
71 street mod
78 930
95 s6 avant
66 ausca duetto
69 1600 race car in progress. for sale
If it is not M10x1.0 then you may have banjo bolt version calibers?
Could be M12x1.0? Some sources mentions M12x1.5 so dunno, do check both.
WWW.EBAY.COM
Banjo Bolts. Caliper Rebuild / Repair Kits. Bremtech premium quality banjo bolt kit with parts for two brake caliper. - 2x M12 x 1.00mm mild steel banjo bolts. Brake Caliper Slider Pins. Brake Caliper Pistons.
Da!
I'm using some Nissan calipers on the back of me raceycar,
and a banjo bolt to inverted flare adapter works a treat.
The Nissan uses something like a 12mm banjo bolt, which is pretty standard.
Any idea what dimensions of the caliper schpigot are?
I've never used the VW calipers, just because I've never run across a set...
The inlet, where the fluid goes in.
A pic would really help, to show if it has a
flat for a banjo crush washer, or a flare at the bottom.
