What is the purpose of this spring
Pdxguy
Does the spring,  #3 on the diagram below, (part number 32311110814), and the ground cable on the universal joint on the steering column (yellow arrow on the third image) perform the same function? Guessing something to do with static electricity not being sent up to the steering wheel? Bought the universal joint/flanges used and it had the cable connected to both flanges, similar to the spring's connection.
I have a rusted spring, not sure how long it will last, and they are NLA. The cable seems a good solution if I am understanding the function correctly.
Thanks,
Dennis
Steer.col.-steer. spin.
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 Flange Z=36 1     32311150426 $42.73
02 Hex bolt M8X35 2 03/1966 07/1977 07119913676 $0.36
03 Spring   1     32311110814 $34.35   ENDED
04 Universal joint   1     32311112359 $24.64   ENDED
04 Universal joint   1     32311112358
05 Flange   1 03/1966 07/1977 32312670180 $93.74   ENDED
05 Flange Z=36 1 03/1966 07/1977 32311150426 $42.73
07 Steering spindle M 14X1,5 1     32311114192     ENDED
07 Steering spindle M 12X1,5 1 03/1966 04/1972 32312482105 $555.77   ENDED
09 Hex nut M12X1,5 1     07119921626 $1.17   ENDED
09 Self-locking hex nut M12X1,5-10-PHR 1     07129900047 $0.62
09 Self-locking hex nut M14X1,5 1     07129922470     ENDED
09 Self-locking hex nut M14X1,5 ZNFE 1     31121095420 $0.88   ENDED
09 Self-locking hex nut M14X1,5-05 ZNS3 1     31106774714 $1.12
10 Wave washer B12 1   07/1977 07119932123 $0.38   ENDED
10 Washer A13/HV-ZNS 1   07/1977 07119901766 $0.30
10 Washer 13-140 HV-ZN 1     07119936442 $1.48
10 Wave washer B14 1     07119932147 $0.20
13 Self-locking hex nut M8 6   03/1987 07129922714 $0.17   ENDED
13 Self-locking hex nut M8 6   07/1977 07129946400 $0.35   ENDED
13 Self-locking hex nut M8-8-ZNNIV SI 6     07129905767 $0.27   ENDED
13 Self-locking hex nut M8-8-ZNNI SI 6     07129906196 $1.60
RealOEM.com - steering column.pdf
