Getrag 245 Shift Selector problem
Chris_B
I will second this.
I had a 4- speed that David Lumbra rebuilt.
It NEVER leaked.
It's the only one I've ever seen that didn't.
I do think that the 5 speed's brutal reverse detent spring is partially to blame for the
245's tendency to leak so much.
  • 10 months later...
On 1/30/2021 at 2:45 AM, 2002iii said:
I've heard you can put up to six seals in there. I would try that before taking the whole transmission apart to swap out the shift shaft.
I had to replace the shift shaft in my 245 because it snapped, it was not a simple process. I had to make a tool to separate the 3 case parts, you also need a good 3 jaw puller. To remove the rear case section the transmission must be in 2nd gear. Then carefully use a punch to press the pins out of the levers without hitting the gears.
There is a design fault with the box, as the rear of the shaft is not supported behind where the cross dowel pins are drilled. It flexes here and breaks through the hole. Mine snapped there, and the first replacement I found was cracked and bent there. Finally found a good one. If you look at later boxes there is a support sleeve / bushing at the back. So I made an oilite bronze bushing to fit.
The flexing is probably what causes the seals to fail quickly.
Also check the casing isn’t cracked where the seal goes in. A guibo that fails can damage that part of the case.
I should have followed up on the resolution to my problem. The end of the shaft fits into a bearing in the case. This bearing was worn, allowing the shaft to flop around. That, and we discovered that the BMW seal was a better fit than aftermarket seals (e.g., Elring).
Chris B.
'73 ex-Malaga
On 2/2/2021 at 9:00 PM, JerryC said:
Hmm... Wonder if a brass bushing made to the seal dimensions can be pushed in ahead of the second seal to reduce slop? Just sayin'. Seems like more than one thing could go wrong, but it might work.
Jerry
That is what I’ve done with a bronze oilite bushing, but from the inside whilst case was apart. To replace snapped selector shaft.
