Coolant Overflow Tank
Schon '02
I have an overflow bottle from an 80's Japanese car, it's small so it fits perfectly behind the driver's headlight on the radiator support without blocking airflow. Never had a problem and like that I can check it without removing the cap like the chrome ones.
  • 7 months later...
On 3/10/2019 at 9:50 AM, TobyB said:
I have found that the type of cap is important, too.
The stock style does not have the valve to re-ingest coolant
from the overflow.  But most aftermarket ones (Stant is what I use, too)
do.
I have also found that a stock or e21 radiator will not puke more coolant than it should
(12% sounds like what I've seen, too) and that while the modern 'completely full'
system is far better for oxidation, it's only needed for cooling in marginal situations.
IF you check your coolant weekly, like you used to have to do back in 1965.
uses a bike drinks bottle
Is this the cap you use? Stant Lev-R-vent #10329
