Rear Break Shock install
ezlnh8u
Hello everyone, I have been looking for a rear shock install wright up, but have not been able to find one, I get allot of hits for the front install but no luck on the rear, I am planning on skipping the shop and installing new bilstein shock for the rear, any leads or advice would be greatly appreciated. Thank you.
Using Tapatalk
Using the good old SEARCH function, I found this.
Hope it helps.
-Bob
-Bob
(current: 1972 Malaga 2002, VIN 2584644, build date July 26, 1972)
Previous: 1973 Sahara 2002 #2585896 (RIP), 1969 1600, 1971 2002, 1964 Triumph Herald convertible, 1965 Triumph Herald convertible, 1961 Triumph TR3A, 1967 Triumph TR4A-irs, 1959 Austin Healey 100/6, and about 10 other cars (most of which were quite boring)...
The fact that there isn't much coverage is because it's pretty self-explanatory.
Jack up rear end -> undo old trailing stud nut -> undo jam-nut in trunk -> push out shock -> take out old rubber strut mounts -> install new rubber mounts -> slide in the new shock (with metal sleeve) -> reconnect bottom to trailing arm stud -> lower the car back down -> bob's your uncle.
I go into it a bit here (with some pics!).....
Edited by AceAndrew
-Bob
Some shocks have a fitting for an allen wrench at the top of the shock shaft which prevents the shaft from spinning when you loosen and tighten the lock nuts.  It took me a few minutes to figure this out while trying to remove the nuts holding the top of the shock to the shock tower in the trunk.
Mark92131
1970 BMW 1600 (Nevada)
