5speed install questions
2joejoe2
I believe the factory shift tower accommodates for the uneven tower mounting bolts.  Maybe when folks modify them (shortening) or aftermarket units are used they are not aligned correctly. I still have the original 4-speed mounts on my car which makes it very difficult to R&R the 5 speed tranny.  I'll think about removing them this year.
FWIW, my 5 speed tranny sits a little off center to the right.
Edited by jgerock
Sure you can.  People don't remove transmissions to change a slave cylinder!
You may have to lower the rear of the transmission though and gather a bunch of extensions to reach from the rear to get at the nuts.
I think I got the trans where I like it. It's about 7mm from the left tunnel trans mount. I was able to flip the slave cylinder with a modified 13mm box wrench. To make the shift tower level I just spaced off the one side with washers....a little gheto I know.
I saw a Inka Tii at the XXX Rootbeer meet this last year with a five speed in it and it had the factory, or what looked like a OEM replacement rubber boot.
76' Fjord Daily SOLD
1986 528e 5 speed Daily
"I don't have a piece of sh*t so I have to envy yours!" - Ferris Bueller
