IE Mechanical Advance Distributor
coolwnc
Which carburetor(s) are you running?
If you are replacing a worn out sloppy distributor with a ruptured vacuum diaphragm and weak mechanical advance springs, or sticking centrifugal weights... then yes, I would call a fresh unit a good move.
I am personally partial to vacuum advance on a single carb-ed car though.  Assuming it is in good working order.
Some people have had trouble in the past with trying to get the IE unit to seal.  Double o-rings, or wrong sized o-rings were the problem and may have been corrected by IE.
I have been running the IE distributor on Vern, my Tii, since May of 2013 with no issues.
Andrew Wilson
I installed one on the F Bomb (she's a tii, so proper ignition advance curve is crucial) and found it to be flawless (I mapped out the advance curve, using an adjustable timing light, just to be sure). The only reason I sold it, was because I had my original unit (008) rebuilt. No issues with sealing or fitment. If I wasn't all nutty about keeping my car mostly original, I'd have kept it.
Paul Wegweiser
