Another Redline Mtl Add
Cyclone101
I had some difficulty shifting from 3rd to 2nd and from 2nd to 1st on my 71 2002, so I thought it good to try and 'fix' it with a better lubricant first, before I go rebuilding it.
Research showed that Redline MTL has had some promising results, but finding it in South Africa is difficult, and expensive! One place charged me $50 per quart...
I did find it at a more reasonable price after a bit of searching, and changed the fluid today, and boy I am satisfied!
I can now shift smoothly up and down without any difficulty, no more waiting 5 mins(exaggeration, if you missed it...) for gears to match up.
I'm definitely sold!
Regards
Jacques
'71 2002 Malaga, fun weekender
'70 2002ti Colorado, Restoration/money pit
'74 2002 turbo in my dreams, sideways...
I suppose i would pay 50 bucks for a smooth tranny, but man, that's steep! Even here in the states(and i live 1.5 hours from where its produced!!) it's gone up in price by 50% in the last couple of years. Glad to hear it worked for you.
 bob
71 2002
85 M635
89 327is
98 M3
 Jacques,
 what gear oil were you using before ??  The reason I ask:  for many many many years I was using the wrong gear oil in the transmission.  I had been using the same stuff in both transmission and final drive.  The final drive requires a Hypoid gear oil, the transmission does not.  Once I installed a non-hypoid into the transmission (I used Redline MTL), shifting went from OK to super-smooth !!
Also, I learned that the transmission requires a GL-4 rated gear oil because of the brass synchros. I learned that most final drive gear oils are rated GL-5, which has sulfur.  Sulfur is harmful to brass, and GL-4 does not contain sulfur.
Here's the long story .....
http://www.bmw2002faq.com/topic/135183-manual-transmission-gear-oil-use-the-right-stuff/
Cheers,
Carl
Edited by OriginalOwner
I can't seem to find the old container, but it was definitely a non-hypoid oil, just can't remember the weight. <br /><br />I changed the fluid about 3years ago.
I know I have the same gear oil in both my rear end and tranny.... I need to change it out >.< I have MTL for my new 5 speed :)
-Nathan
