Replace Motor Mounts Without Engine Hoist?
Grover
Did this today.  Had great luck!  The 4x4 with a racheting tie down works well.  I found it worked best when running in a loop (goes under car 2x to complete a circle).
Notes:
  • Alignment was much easy, the tricky part was figuring out how to loosen the screws with my limited tools and limited space.
  • Racheting wrenches are highly recommended in the 17mm and 13mm sizes (as well as sockets with extensions of varying lengths)
  • Driver Side is best done from the top, passenger side must be done from underneath
  • You will need a 6mm hex bolt for one of the passenger side mounts
  • I wasn't able to figure out a way to release the tension from the racheting tie downs smoothly.  Be careful!
1976 Fjord Blue BMW 2002
2002 Topaz Blue BMW M3 Convertible
