strange clutch issue (video included)
1971Ginger
..... " looking underneath the car while
having a friend press the pedal and
while pressing slowly I noticed
that the master cylinder was
not engaging at all but when
pressing on the
pedal quicker.. "
- bleed the system with a pressure bleeder
- are you getting good flow out of the slave cyl. bleeder?
- master cylinder is dead
- rubber hose is dead
understand the function of each component
study the system
'64 R27 250cc #383851 18,000m
I'm assuming new cylinders last more than 1.5 years. So you're left with a linkage issue, a bleeding problem or something with the hose. I agree, if the hose is swollen in the inside, you would expect to see reduced flow of fluid at bleeder. What did you mean by "master cylinder not engaging"?
On the linkage front, I believe one of the manuals has a dimension for that. Does yours have the adjustable push rod on slave?
I went throught his twice. Exact same issue he is having. by not engaging he is meaning the pedal just sink to the floor....no pedal pressure. Both of mine were the same age as his and both mine were bleeding by internally. Don't make them like they used to
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
