Modern Lightbulb Equivalent...
Rocan
Hey there all... My flasher relay started to give out on me and since I now have a blown bulb I figured it was time to do a complete turn signal and running light fix. I have tried a search but could not come up with a consistant answer.
Anyone know what bulbs fit in squaretails? I know about the wattage and not melting out the lenses, but I don't know the actual size of the bulbs. Perhaps we can compile a useful list and I can make a writeup for the FAQ section?
Response needed ASAP... I'm doing this in the morning :)[/i]
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
The old light numbers are still active. I just go to the parts counter and they have em if theyre not on the rack, they can look em up too.
-Nathan
Hint : use only Silver Tip Bulbs (OSRAM) bmw german
bulbs - no oxidation of socket or bulbe tip, best quality, bright output,
you have a BMW - don't use krap bulbs
go out to the car- open trunk - unscrew lens securing plactic
nuts, inspect the bulbs in there now, and look at condition of the sockets.
CLEAN socket metal and treat with WURTH or simular "contact oil" to prevent oxidation
you'll find the fine rope seal and thick foam rubber gasket
are toast. Now you get to restore yer SQUARE lights.
Clean reflectors and paint with either WHITE or CHROME
rattle can paint. Throughly wash the lens. Get all the 40-year
grime out of the inside little crannies. DO NOT OVER TIGHTEN
THE LENS PLASTIC NUTS!! - the lens studs will pull out of
the plactic and then your fuched!
'64 R27 250cc #383851 18,000m
This is a pretty good list: (And note: current OSRAM bulbs say "Made in China" - so much for good German bulbs.
parking light/front turn signal
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
97
Stop light
1156
Back up light
1003
1003LL Long Life Upgrade: Up to twice the life of the standard lamp
Front/rear sidemarker dont think I have these!?!
97
Dome light
1893
Instrument-general
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Bob Napier
Thanks guys!
Yeah, restoring the tails is definitely in order. I have to find some new plastic covers for mine, since they are completely trashed.
I'm also all for good quality bulbs, but for the time being I'll have to settle for what the local store has just so that my car is "legal"
A bunch of Bikes...
Hi--
Here is my list of bulbs for 2002's. Someday maybe Steve Kupper will put this in the FAQ area for easy user reference. While some US bulbs, such as 1156 and 1157, will work pretty well they draw more current than BMW planned and may provide less light. CD's comment about "silver tip" means that a nickel plated base does not oxidize so easily as a brass base, so it will provide fewer problems down the road; do not confuse the base with the black, blue or silver shield on the top end of most headlamp bulbs. Note that the European bulb types usually have a shorter life rating than US bulbs so carrying a spare is a good idea; order a few next time you get parts from a BMW supplier.
Appendix bulbs for 2002's expanded 130120.doc
Larry Ayers
’73 Malaga— first car, now gone
'74tii Malaga
