Konrads Maximillian Frankenstein
Kpeters
Makes sense to me. Gaskets/O-rings may be expensive but would probably be a good project. If it fits in the budget I would recommend it.
-Nathan
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Yeah but its not only that I think the whole thing has to be redone! It's in really REALLY bad shape so bad that to start it i have to pour gas down the manifold into the cylinders.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
I would assume, that you could buy a rebuild kit for it? May not be as easy to get as a carb one, but 10 times better than a Solex! I think a guy on here did a write up on it not long ago, i'll see if i can find it for ya.
Edit: He started into it, not sure if he did it all or not. May be able to ask him if he did.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,350733/postdays,0/postorder,asc/topic_view,/start,30/
-Nathan
Interesting reading my allen screw caps on the top are all stuck and deformed wonder how i'll take that out.
Thanks for the link!
E23 730 1978
Pull the pump off and soak all the parts in liquid wrench for a while, then find the right size allen wrench. Liquid wrench will be your best friend with that car, it works miracles on my cars and tractors!n Other than that I dont have many other ideas on how to get it out, just gotta use a lot of ingenuity I guess :P
-Nathan
Yeah problem is some one tried to take out the allen screws before and deformed them agh.
E23 730 1978
You could use a dremel and make em the next size up in Metric or American? That would probably work for ya. Gonna take time though :/
-Nathan
Yeah it will take a lot of time!
E23 730 1978
May save ya some money though in the long run? Also depends on how bored you are on a Saturday night :P
-Nathan
  • 2 months later...
Well this weekend I finally got angry enough with the Kugel Fischer to tear it apart! Now it's nothing more than tubes on a cardboard box.
Now I need to take off that pump, get a new oil filter housing, hoses, manifold and carb and I'm good to go!
It's a shame it has to go but....tooo expensive for a car that's not an original tii.
PS: Notice the PVC plumbing the previous owner did! :S
Some pics:
E23 730 1978
  • 2 months later...
Crappy carb in! Agh...the kugelfischer :`(
And the instrument cluster resto!
E23 730 1978
  • 1 month later...
Still taking parts off from the kugelfischer system and finding out how bad the cooling system and starter was.
Will be uploading some more pictures of the fresh new parts that are going in, car needs to be in great mechanical condition before it hits the body shop.
E23 730 1978
  • 1 month later...
More work on the car this time trying to stop the rust before it gets worse and preparing the engine to receive the new accesories, and bolts & nuts.
E23 730 1978
  • 1 month later...
The beast has awaken!
The car started, there was a puff of blue smoke and off it went had to adjust the timing to keep it on and finally I got a more or less stable idle at 1000rpm. Here are all the pics of the event hopefully I'll be able to upload a video soon.
There was an exhaust leak on the intake manifold and it needs a valve adjustment badly, but besides that and the slight blue smoke its not so bad... to be honest for a car that had been sitting around 15 years its pretty cool!
E23 730 1978
  • 3 months later...
Some tune up work for my 2002:
Changing Points:
Changing Exhaust Gaskets:
The filthy fusebox:
After all this I still think I got a rod knock but the car behaves a lot better.
Some vids of the engine sound:
Before:
http://youtu.be/CiMjhpeOZIk
After:
http://youtu.be/35EZb2KL3n8
E23 730 1978
