Hand Brake Cables on 320i brake upgrade
SeanH
Hey all,
Just finished my rear 320i drums and have found that the ebrake cable is long enough to hook onto the lever arm of the brake pad but its so short that it extends the brakes and I'm unable to get the brake drum installed.
Do I need to use 320i brake cables?
Thanks!
Sean
Seconded.
Turbo E-brake cables are the way to go. Since the 250mm E21 drums were first designed for the 2002 Turbo, the Turbo's E-brake cables will work. I have them; they work.
P/N is 34 41 1 110 971.
ClayW
or the other fix (which is also documented in a thread on this same topic) is to grind a little off the pad separator plate.
This is what I did. Pretty easy, works perfectly.
John Capoccia
Sierra Madre, CA
