What's all this about then?
Marshizzle
I was doing a little work and noticed two things; a hole in the gearbox and a clip that is unsecured. I thought I'd snap some pictures and throw it up here, and ask everyone what these things are.
Item 1, as you can see, is the hole. The hole gives me a view into the gearbox and I can see bits moving when I push the car while it's in gear. Item 2, as you can again see, is the clip. The clip has nothing to attach to (at least near by) so it's just rattling around.
So, if anyone can help out a new guy, I'd appreciate it. Thanks!
New to the 2002, new to working on cars all together.
-Marshall
#1 is for viewing the timing marks on your flywheel when you are setting your timing. You might want to clean the marks on the flywheel with a long Q-tip, then put a dab of paint on them to make them easier to view when using your timing light.
#2 ??. not sure, been a long time since I've seen a stock set up. when I find things like that on customer cars I usually move the clip along the line its on and usually it'll line up with it's long lost home at some point along its travel.
HTH,
-s
Shad
'70 2002 #671 "Bimmerschmitt"
'70 2002 BADUDA aka 'Wall Art'
'72 2002 #672 Sold
'73 2002 Sold
'79 528i Daily Driver (future ETC Clone)
As mentioned, #1 is the sight hole for the timing ball.
#2 is a clip for an emissions line. It looks as if the line was replaced and cut a little short. I'd say that it should be secured by the 10mm bolt at it's 4-o'clock position.
Cheers!
1976 BMW 2002
1990 BMW 325is (newest addition)
1990 Porsche 964 C4 Cabriolet
your#2 is a EGR (exhaust gas recirculation) = BAD on any motor
dumps nasty exhaust junque into the intake manifold,
carbons up the intake manifold, intake ports, intake valves = very bad
remove it and plug the ends where the hose connected
remove the valve, vacuum controling valve for the system
and have a really happy motor
if you have a AIR PUMP - you should also remove that
nasty air leaking, back firing, cluttering system as well
get your motor running pure. UNLESS your state inspectors
need to see such krap for you to PASS State Emissions Testing ?
'64 R27 250cc #383851 18,000m
