Throttle bushing on 74tii
dharvey
Discovered my outboard half of the bushing for the pivot linkage at the block was gone. Looking through the stash of odds and ends I couldn't find anything, then I stumbled across an empty 30.06 shell and wouldn't you know it, by cutting out a section with a tubeing cutter, it fitts well enough to get by till I can get the correct one.
Very resourceful yes - but we need a picture for reference purposes.
The little nylon split bushings on the block pivot (and the firewall pivot) are inexpensive. I added a flat nylon washer to mine to reduce the linkage slop (thanks to Justin Gerry for the tip).
