Fuel Sender Re-assembly Question
jhenard
Just took apart the fuel level sender to check that everything was working.
Other FAQ posts indicate a screen on the bottom of the fuel level sender.
Was this true of all models? My 72 tii has a fuel pick-up which I assume has a screen and a seperate fuel level sender that does not have one.
An artticle in the BMW enthusiasts guide does not mention a screen in the level sender rebuild.
Where are the screens?
Thanks
since the screen is for the fuel itself, the tii sender unit "can" doesn't need a screen 'cause the pickup isn't inside the can as it is on the carbureted cars.
I'm going by memory as I've not messed with tii's too much, but that's what I seem to remember.
