Bmw 1602 turbo
Robert
Awesome, What do you do for work that allows you time for that :D
I come to sweden ever other summer to check out Vermland and stockholm. Maybe i'll swing by.
  • 1 month later...
fifty: haha why not :)
Not much time for my own car since I opend my speedshop www.dynotech.se . Made M20 world rekord on standard parts last week. Standard M20B25 with changed camshaft and springs, rest untouched. Gt42 turbo 62mm compressor and 67mm turbine. VEMS managmentsystem running on e85 fuel.
Made 647whp and 790wnm @ 1.94bar of boost on my Dynapack dyno.
You'll find the thread about it here -> http://www.e30tech.com/forum/showthread.php?t=105048
Next update I will post some dyno result from an Boosted M10 :)
  • 4 months later...
I can't login on my old user on this forum since my registered email doesn't work any more..
Anyway I have made some small tests on the dyno.
470whp in my dynapack 5000 dyno @ 14psi boost and max power on 8820rpm
I have the M10 WR Record with only ground boost on the wastegate.
575whp with 20psi of boost. More to come I want to
Last run made 740whp with 95% duty on my new bosch 2200cc injectors. I have to raise the fuelpressure and give it more boost :)
Robert
Dynotech
Do you have an Email, I would love to ask you some questions about my build , yours is very inspiring.
Also, any recent pictures or videos?
  • 4 weeks later...
Yes Im using redline....
Tested superstage alittle with cracks in my turbo exhaust so I lost allot of register to run on, so It was hard to drive on superstage.
Also found a lubrication failure when reving the engine hard for a couple of minutes. The oil will not have time to come back on the oilsump when reving 9500-10000rpm.... I also have to find a solution on my heavyduty oil pump m10 pump with m30 rotor. Bmw 02 standard chain will not handle the force from the m30rotor racing oil + revs... I also have a special solution on the oil in the head problem..
Here's a teaser
http://www.youtube.com/watch?v=uJCrJdixHCI
Robert
Dynotech
  • 3 weeks later...
Here is 2 clips from the beast in my dyno!
http://www.youtube.com/watch?v=2NB2T734FjY
http://www.youtube.com/watch?v=KqZrmsKtiz8
Atm Im waiting on my new inconel exhaust valves, and my 2nd custom camshaft, alittle change to the timing, hope it will perform as I want. I'm also building a new turbo exhaust pipe changing from SS steel to standard, I want to get rid of all the cracks...
All these changes and meybe I can finaly reach my goal :)
Robert
Dynotech
  • 4 weeks later...
  • 8 months later...
