Signal flasher upgrade easy to do & what a difference
02hobiedave
On 7/2/2021 at 2:48 PM, Vicleonardo1 said:
When creating the 3 pronged loom to connect to the original socket, what size spade connectors are used to fit into the socket?
Err, I don't think this is really necessary, as the original spade terminals are the same size as the spades on all the modern flasher relays. So just use a jeweler's screwdriver to release the locking tabs, pull out the female spades from the socket, bend the locking tabs back out, and then just stick them back in the new 'correct' spots to mate with your new flasher.  At least that's what I did, so the new flasher just now plugs into the factory socket, and then just need to run the new/extra ground wire.
