Electric fan controller - where to get one?
Schweineback
I scored an electric fan which I want to use to replace the stock fan, and place it in front of the radiator. I want it to switch on only at higher temperatures of the coolant fluid and have it idle the rest of the time. That means it needs some (programmable) intelligent device - aka the controller - to steer it. Any one knows of such a device and where to buy it?
Dreamed I was an Eskimo.
I bought mine at Pep Boys. I wanted the adjustable Hayden unit like you want but it was $70 so I went with the cheaper $30 not adjustable unit. Mine was super easy to install. No drilling or tapping for a coolant temp sensor. It has a brass rod that you insert in between the radiator fins as a temp sensor. It turns on the fan at 185 degrees ( I think) and shuts off at around 170. Working good so far. It also has a lifetime warranty. Check any autopart store or Summit. Hope this helps.
This is the one I bought....
http://store.summitracing.com/partdetail.asp?autofilter=1∂=HDA%2D3652&N=700+115&autoview=sku
This one is very adjustable....
http://store.summitracing.com/partdetail.asp?autofilter=1∂=HDA%2D3651&N=700+115&autoview=sku
David
David G.
1989 Volvo 240 Wagon "Da Brick" Daily driver
1992 Nissan Sentra SE-R "Hitomi" Sleeping. Waiting for NEO VVL!!
1976 BMW 2002 "Diana" The never ending project!!!
Get the 82degree temp switch for the Aux fan on an E30. Fit that to the bottom of your radiator (get a rad shop to weld in a bung). Then check out the wiring diagram on the FAQ pages - it very easy to follow. Beaner7102
Beaker,
Get this instead. I have it and it's fantastic. It will allow you to run your fan at variable speeds depending on the temp settings you determine.
http://www.spalusa.com/fans/automated/accessories/fanpwm.html
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
  • 4 months later...
David
hi guys.,
i also mine hear summit i agree with MAD..
summit racing is the best place to have a survey to find your problem,.
please try this.,.
regards.,.
Fanimation Fans
