Just bought a 76
mickth
Hello,
I just bought a 76 2002. Pretty good shape. Not a show car by any means. But, no rust. That's a good start. Here are a few things that need fixing:
The accelerator pedal seems very sticky. Not sure why.
The automatic gear indicator is missing
The side blinkers aren't working
Starts a little slow.
Very hard to steer.
Anyway, these are the biggies.
Mick
Way to go! I've had my'76 since February. Here's what I know:
The accelerator pedal seems very sticky. Not sure why. [spray some lithium or other similar grease on the upper rear part of the pedal where the linkage rubs.]
The automatic gear indicator is missing [A rare piece - put request out on the WTB forum here.]
The side blinkers aren't working [Could be lots of things. If fronts are working, it's probably burned out bulbs, loose wire, short or bad ground.]
Starts a little slow. [iF you mean turns over slowly, it's likely battery. If it's slow to catch, it needs tune-up.]
Very hard to steer. [Hey, that's the way they are! Check grease in steering box. Front tires may be under-inflated.]
In any event, I'd suggest full tune-up, carb adjustment and all fluids changed. You did pick the best '02 forum!
1976 2002 Inka
2008 M5 Sapphire Black Metallic, 6-speed
lubricate all linkage, pedal, trans cable, levers,
make sure nothing is rubbing or touching
anything it should'nt. Plastic sleeve should be on the
shaft riding on the back of the gas pedal - order any part
you need from any BMW Dealer - really.
and your car needs to be updated - SERVICED COMPLETLY
because the seller didn't. All of the electrical system needs
examination, connections cleaned, tightened, inspection
for loose connections, broken wires, poor connections.
Replace the fuses and clean the fuse holders (disconnect
the battery FIRST ! )
Do it now, do it completly, and drive forever,
well almost forever trouble free.
tuff steering ? tire pressures, TOO FAT TIRES ??
bad upper strut bearing mounts ? no oil in the
steering gearbox? wrong gear oil, or GREASE
(SHOULDN'T BE GREASE) IN THE STEERING GEAR?
CLEAN OUT THE CRUD UNDER THE CARPET
where the brake pedal piviot lives also - lubricate the pedal
and out under the hood where the brake pedal piviots
behind the booster
stiff steering can be many things ? ? ?
do this also -
'64 R27 250cc #383851 18,000m
CD gave you a pretty amazing run-down of items to touch. One thing that bears repeating....flush brakes and bleed thoroughly. You'll see a vast improvement and it'll be a lot safer. Not a hard job, search the forum. Good luck, enjoy, keep us informed and keep your checkbook warm!
'74 2002
4224350
Ambulatory on 2/4/9!!!
Now the hard shit begins
