Bench test ---tii fuel pump
Hutton
Car sitting for a while. I just changed plugs, filters, oil and fresh gas.
Turn the key and no response from the electric fuel pump.
Suggestion/method with bench test --- tii fuel pump
Chris Hutton
72 02tii Ceylon 2761758
71 02 Sunroof Riviera 2574316
68 1600 Bristol 1565358
88 535is sold
Crawl under the car with the key on and bang on it with a wrench. Might just wake it up. That method got me home one day.
I ended up replacing mine because it would not run without the impact start proceedure.
Good luck!
Patman
74 2002tii known as "The Pickle"
1972 2000tii Touring #3422489
FAQ member #5
don't remove the pump -
test light or volt meter check at the pump,
check for break in wiring through trunk,
and give a calibrated 2-oz. "doink' with
BMW Special Tool # 11.99.0.000.001
add MARVEL MYSTERY OIL to the gas tank
to prevent sticking in the future. (2-0z. per full tank)
'64 R27 250cc #383851 18,000m
