Turbo Megasquirt EDIS 2.1L Forged M10 build-up. IT'S ALIVE!
Howdy,
My 35 year old M10 was slowly leaking (then burning) oil, which is understandable for a machine that has endured so many years of punishment. Who knows what the P.O. had done to this thing, I have seen some odd things over the course of our time together. It was time to rebuild. I acquired a free Garrett TB0368 (T3) and decided I would build a turbo engine. While browsing through the for sale section of the board, I saw that Andrew (handle: 2590402) had a bunch of turbo parts for sale. Well long story short, I got a short block shipped from PA to CA and started the build.
This is the block as it arrived (minus motor mount):
As you can see, the pistons are of the Ross forged variety in the 91.4mm size, yielding a displacement of 2.1 litres. The block also features Ireland Engineering coated "race" main and rod bearings, and the clearances are all to spec.
I will be running this water cooled T3, seen here on a table at Starbuck's:
Mid tear-down
The old head was crusty...
So I machined/refreshed it \/ \/ \/
Sparkly rockers:
Installed new valve guide seals from the Victor Reinz set:
Throw in all the valves and the cam. The valves take literally about a minute apiece to remove or install with a valve tool...
Installed the rocker shafts and rockers. Yes, it is possible to do this completely without a cam tool (with the stock cam).
Next was to take care of the front covers. They were dirty.
Here is the lower cover with the new seals, oil pump chain, and Graf water pump:
I drilled and tapped the front timing cover for 1/2" NPT for the turbo oil drain. Then I went ahead and plugged it for the planned break in period:
Put on the head with a BMP turbo cutting ring head gasket for a bored engine. This gasket is made by Goetze and is nice in an epic fashion. I should end up with 8.5:1 compression. New head bolts of course, yowe.
Next came the crank scraper from www.crank-scrapers.com. Kevin was great to do business with.
As it showed up:
It has trap doors so the oil doesn't splosh up the side of the block during hard left turns but still allows the oil to drain down from the top end.
I had to do a little grinding to get a perfect fit but as you can see, it can't get much closer. Check out the clearance to the counterweights:
And the rod studs:
Now that the engine was buttoned up, it was just time to install the nice clean oil pan. I painted it a light color so I could easily see any leaks. You are not supposed to use any gaskets with this scraper, just RTV.
Next was to install all of the crank trigger components. I made this bracket out of aluminum. Like every other bracket, it bolts to the two lower water pump bolts:
Lucky me! My old engine already had the euro/non-smog front pulley. I added some weld to it and had it machined to fit the Ford Escort 36-1 trigger wheel. I pressed it on after getting all of the alignment figured out.
Everything mounted up:
This is how it sits with the missing tooth 90* or 9 teeth ahead of the VR sensor at TDC.
And the completed engine. You can see the fuel pump block off plate I made. I will be running a '91 318i unit.
Finally back at home.
Coming up next: Megasquirt assembly and installation.
-Cody
'73 Deuce, the "Snailmobile"
The Engine looks awesome. Hows the megasquirt programing working out? I cant wait to see more pictures and the dyno chart i never got to see.
-Andrew
1974 Cinnabar M2: S14/320CR/391LSD/Turbo Exhaust/Turbo Radiator/323 Trailing Arms/Ground Control Coilovers
Thanks Andrew. The programming was kind of tough since I had never done it before and the configurator was confusing because the firmware INI files weren't agreeing. I did eventually get it running right by the end of the night though.
My buddy DJ just got your manifold. It's a small world.
-Cody
Great build dude! Looks like it will be quite the car.
Im pretty new to 2002's and im wondering what kind of horsepower the drive line can take. I know m10's are good for some boost. One e30 guy was making upwards of 350whp on an m10. Thanks!
Keep it up!
Cars:
1991 325i Turbo m50
Im no turbo wiz, but from what i hear you should break in a turbo motor with boost.
Great build though - Cant wait to see how you go!
this is true, but only a lower amount of boost, say you want to run about 10psi, run 3-5psi for run in.
holy negative camber batman!!!
02 Golf Yellow cruising the border of NSW/VIC!
tii pistons, 293, double valve springs, 40mm DCOE's, sump baffle, sway bars, lowered, 5spd, big brakes, 3pc wheels, bucket seats. Approx 150+hp
I have seen that flat tops with the e12 make about 8:1 so a small "dome" like mine should make about 8.5:1. The stock pistons on some of the m10's including mine had the small piano shaped dome to them and had 8.5:1.
I will be running the Volvo downpipe and 2.5" straight pipe to possibly a small glasspack if it is too loud.
The guy with the 360hp m10 is Good & Tight on the BFc and he's running an e30. Here is a thread with the dyno chart:
http://forums.bimmerforums.com/forum/showthread.php?t=567355
-Cody
