steering box / re-fill with ? ( prefer synthetic )
inka.inka
THE key to correct oil speck for the steering gear is HIGH SHEAR
Please use only " HYPOID" SAE 90 gear lubricant -
and not synthetics - same oil for the rear diff.
NOT in the trans ! No HYPOID, or GL-5 grade gear oils in the gear box
Use ATF(winter), or GL-4 75/80(other 3-seasons) in the gearbox
and it's DARK out there now -
ALIGN yer headlights
021600HEADLIGHTAIM1967.jpg[/b]
'64 R27 250cc #383851 18,000m
Why not a good synthetic? How soon should I be expecting trouble because I have been using a good synthetic in all my boxes and engine since 1978? Any day now or in another 30 years?
The only thing I don't have is all the black gunk in the engine from dino (I really don't miss it).
The BMW '02 Restoration Guide (Mike Maccartney)
recommends using wheel bearing grease (or some
equivalent) instead of oil--less chance of leakage ??? =
THAT would be C-V joint grease which has high shear
and impact and fluid flowing properties -
but may be stiffer to turn when cold/frozzen.
