S14 engine in BMW 2002
Robberrick
Has anybody installed an S14/M3 engine in a RHD 2002?
If so I would like to make contact with you as I was wondering how you got around the problem of exhaust manifold and steering box.
I have heard that it is better to fit rack and pinion out of later BMW but not sure which model.
71 BMW 2002 racecar with S14 motor.
Theres actually 2 s14 powered 02's in Brisbane. Contact Skippy_the_Bush_Kangaroo or AlanM on this board. Also, i suggest you look for Skippy's project blog in the project blog section. Both these fellas got around the exhaust issue by using 2 steering rods from a Toyota Tarago to eliminate that donut.
Cheers,
Tom
72tii - Whitey
74 - Blacky
It really depends what you want the car for and how much time and money your prepared to "invest" in the car.
I used the tarago coupling method as told to me by Allan Moore. It doesn't change the geometry or involve any cutting or welding , so there are no issues with the Transport department. This method removes the rubber donut and free's up a lot of space and allows for some decent headers to be made.
Feel free to shoot me an email if you have any more questions or would like a photo of anything. By no means am I an expert mechanic or fabricator, but I'll help out where I can.
"Why is one of my reverse lights on in 4th?"
If you do the e21/whatever rack conversion a standard m2 manifold still won't fit, but you will have a lot more space to work with. However, only go down this route if you're prepared to play around with the set up - currently there's no exact 'how-to' on this conversion, although it can be made to work.
Find your self a very good exhaust maker and show him the problem -if you're in the UK there's a guy whose just done this so his fabricator may be able to knock off another fairly easily.
Good luck, Nick
