rear drum service
CornDog
Does anyone have an easy way (or any way for that matter) to put the bottom retaining spring in behind the "anchor plate"?
I have fought and fought and feel that it is a losing battle...do I need a special tool, technique, both, or am I just in need of some serious coaching? You be the judge.
thanks,
Sam
btw it is a 1976 2002 with factory drums
seems everyone has a favorite technique. here's how I do it:
1) put the spring ends in the holes in both shoes and use a Quick-Grip clamp on each end. The middle of the spring is outside of the center plate.
2) put the tip of a long 3/16" screwdriver in the slot of the centerplate and lift the screwdriver handle end to flip the center of the spring over the plate
Bob
BMWCCA #4844 (#297 of The 308)
1974 2002 Sahara, MM 2400 Rally engine, MM 5 speed and conversion
1976 2002A Anthracite parts car
1991 525i AlpinweiB II
2002 330ci AlpinweiB III
2007 530xiT Titanium Silver
I had a mojor strugel with my brake job until I put in both spring ends in the hole first. Then took a large screw driver and gave it a pop up and towards the drive shaft at about a 45 degree angle. It went in so smooth I could hardly beleive it. But first make sure everything else is lined up and flat againt the backing plate. the spring was the last thing i did.
Good luck
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
