One piece dash removal
lilblackcat
i've removed several without removing the windshield...i bout a cheap right angle screwdriver at autozone which permits access the screws....
lift the windshield rubber about 1/4 in from each corner and you'll see the screws...another option is to drill the screw heads...i've done that on rusty screws that a screwdriver wouldn't budge
I've taken a dozen out and always pulled the glass--thought i could get at the 2 front screws but they are very tight to the windshield and buried under the gasket--also fairly substantial in size. I'd have to see it done to believe it without pulling the windscreen--imho---Brent
It's doable. Just be patient and take a break if you get frustrated. I've removed a few one piece dashes w/o removing the glass. Good luck
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
