73' Round Verona Full Resto
  • Replies 126
  • Created
  • Last Reply
Top Posters In This Topic
  • 4 weeks later...
There has been progress but i'll update properly when i have time, this here is some creativity due to my lack of planning ahead. I degreased the car before removing the engine and sub to realise that once the engine was removed there was still a lot of dirt/grease, and with no sub it made for hard moving.
So i came up with this, an indoor car wash. Worked a treat!
dont worry about the electricity...
there is a lot more water in there than you think, so much so that i couldn't lift the plastic.
__________________
1972 RHD Auto - Sold
1973 RHD Verona - Project
1974 RHD chamonix - Towed
  • 1 month later...
how's the car going? long time no update.
this car doesn't happen to be the 2002 that i see parked in domain rd all the time is it??
Brent May - Swinburne Uni
1974 2002 Resto:
IE 10.5:1 Pistons, IE header, IE urethane bits, Bilstein Sport Shocks, Whiteline Swaybars, 45DCOE Webers, 304 cam..
UPDATE.
Anyway its been a busy few weeks. Basically just stripped the car. Just got the headliner and scripting left, but annoyingly i left organising the painters pretty late and the bloke said he'll fit me in start of next year.
So i'll be mad busy trying to get everything ready to bolt back onto the car before it comes back at the end of Jan.
bonnet and boot still on for space reasons
empty engine bay, except for that damn speedo, still cant get it out!!
the car is amazingly dusty, not sure how to clean it all out
the dreaded foot well, not too bad, just a little surface rust.
clean wheel well
got to love that rear end
it wouldn't be an 02 with out some proper rust, hopefully not too bad
__________________
its like a nut on the inside of the boot, little confusing but you will get it just inspect it and twist it and you should get it.
holy negative camber batman!!!
02 Golf Yellow cruising the border of NSW/VIC!
tii pistons, 293, double valve springs, 40mm DCOE's, sump baffle, sway bars, lowered, 5spd, big brakes, 3pc wheels, bucket seats. Approx 150+hp
yeah tried that with no luck, unfortunately there had been very few nuts that have wanted to come off due to all the dust this car has seen, i'll just keep spraying it and twisting.
__________________
Hey mate, howd you go with the headliner?
Neither myself nor Bill can remember exactly but with those press in metal clip things, i think we pinched them with some long nose pliers but it might be better if you post up on the forum and see if you get any hits.
Tom
72tii - Whitey
74 - Blacky
did a bit of work today:
with summer coming i thought i'd invest in some air con
wool is a good insulator so that should keep the cold air in the car
worked ok, not great
hand cleaned the interior, took lots of dirty water and time.
finally worked out how to get this thing out.
thinking about getting this colour as my interior, i would like the white/gray bits to be fewer, but something along these lines would be good, black with a hint of something.
__________________
