Original 2002 air filter on a Weber?
jc4me2
Hey guys is this possible to do? I know that my old Solex has an oval opeing and the Weber doesn't. Also, will I lose performance v. the square ones most Weber people use? And if I do use the original, how important is the peice that runs to the snorkel, mine is missing.
I don't often see people with the old air box's, are they rare, or just nobody likes them? Mine is grey and appears to be original, is the correct?
Thanks, Jordan
JAM Engineering, a long time Roundel advertiser has them in stock. $35 or so if I recall. Google them.
Good Luck,
George
74 inka
www.mobileinspections.com
Try the search. This topic has been addressed ad infinitum. Tin snips, a little imagination and some foam to take up any open gaps . . . Someone posted pictures of a dandy red one. Rimspoke?
I would be concerned about the weight of the air filter housing. As you know, the original is supported by brackets from the base of the manifold. Most of the modified versions seems bolted onto the top of the carburettor. Dont think the carb was designed to handle that load, but maybe others have superior knowledge.
Good luck
ANY auto repair shop that has a WorldPac wholesale account can order the adaptor by that part # 99004 351. If they try to tell you it's not avalible TELL them to CALL it in to their salesman, it is avalible!
List price is $53.42.
http://www.worldpac.com/ owns http://www.redlineweber.com You can get ANY RedlineWeber part through any shop that has an account w/ WorldPac!
Sorry though, but the shop I work for does not sell parts mail order, only in person or to be installed on your car.
Other Weber parts and carburetor suppliers are...
http://www.jameng.com
they have a different version of air cleaner adapter, your choice. #0-2200-0-209 online price $32
http://www.racetep.com/
Sells Redlineweber products.
http://www.piercemanifolds.com/
http://www.gicp.com/weber.htm
Tom Jones
got acouple in the parts bin yours for shipping from 78377
DA Beater
has a plate bolted on to the carb and the stock filter is mounted on the plate
Damn wish I had a camera to show you.
For Weber dgav dfav 32/36 38/38 aircleaner adapter for using a stock solex 2bbl (2 barrel) DTITA airfilter housing.
http://www.redlineweber.com adapter #99004 351, gasket #99005 069
http://www.jameng.com kit #0-2200-0-209
Trim off the spotwelded funnel portion from under the 2bbl airfilter housing LEAVING the flat portion on for strength. LEAVE the inner funnel INTACT.
If you're lucky the easiest way is to cut one slot and wind/twist off the flange with a large pair of needlenose vicegrips. It's similar to opening an can of sardeens. Then carefully grind the rest smooth and paint to taste.
For a gasket Trim and re-use the stock solex > airfilter rubber gasket to fit.
BMW #
If done cleanly this allows the filter housing to fit and attach as original WITHOUT having to drill holes and bolting to the carb!
It'd be nice if someone would post pictures of before during and after.
Tom Jones
For Weber 32/36 dgav dgv dgev and 38/38 dfv dfav dvev air cleaner adapter for using a stock solex 2bbl (2 barrel) DTITA airfilter housing.
Trim off the spot welded funnel portion from under the 2bbl air filter housing LEAVING the flat portion on for strength. LEAVE the inner short funnel INTACT.
BMW #13 71 1 263 041
If done cleanly this allows the filter housing to fit and attach as original WITHOUT having to drill ugly holes and bolting to the carb!
See http://www.realoem.com/bmw/ or http://www.2002tii.org/phpmyfaq/index.php?action=artikel&cat=220447&id=62&artlang=en for bmw part # info for the original airfilter housing mounting hardware and brackets.
It'd shore be nice for someone to post pictures of before during and after. :)
Tom Jones
