What do you think?
Pinepig
RAD!
That looks great!
Does anything rub?
I'd go a tiny bit lower in the front on my car but I have rub at full lock with 206/60-13s on 6 inch 25mm offset Cosmics.
I know the 205s are wide but they came with the car so I won't replace them until they wear out.
Again, looking superb!
Andrew
1963 Vespa VNB
1972 BMW 2002 - Sold :-(
1972 Porsche 911T - Sold :-(
Yes they lower the car and you get the visual of a lowered car. But your handling will suffer severely.
Get shorter springs instead. Most of them are stiffer too.
this is a MYTH. cut springs are fine. you *RAISE* the spring rate based on a percentage of the coil that remains vs. was there originally. so, you might need stiffer shocks to match the springs, but that is all. depends on what you are doing with it, type of roads etc... :)
p.s. those baskets look SWEET on that SWEET car!! :)
I also cut mine without removing them. I did it with a Dremel and it was a pain in the ass but it can be done. Mine was spur of the moment though. I should have waited a couple weeks as I wound up pulling and rebuilding the entire front end.
1963 Vespa VNB
