What happens if I unplug the passage and install the plastic vent tubes in my trunk in a Sunroofed car?
71 2002
90 E30 M3
99 E39 528i
production run, the headliner tends to blow out at speed when the sunroof is open...but it might be fun to try--especially if you need a new headliner anyway!
Let us know what happens...
Cool... I might try it... I need to tweak my sunroof cables anyway and it might save me time in the removal of the headliner... :)
71 2002
90 E30 M3
99 E39 528i
the vent tubes in place and I've been 90 with the roof open and no ill effects to date. But now I'm nervous, especially since it's a new headliner!.
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
I'm sure it's one of those instances where 1 out of 5,000 did it and then they had to make changes...
I'm going to intall them to help with getting more fresh air circulated.... more important to me than the possibility of the headliner getting tweaked out.
71 2002
90 E30 M3
99 E39 528i
Yea, I have them in the back of mine (factory sunroof). I am sure some PO changed them. No problems to report here, and I use my sunroof fairly often. The problem might only show up if the sun-roof is the only vent open(ie no windows or def vents) since my Jetta which did have flow through vents had some slight billowing if all other vents were closed. YMMV
