Starter bracket - later model starter
zambo
Go to solution Solved by Son of Marty,
With the car back from panel and paint and the engine up on a stand I was looking at the later model (5 series) starter I intend to install and note the support bracket from the OEM starter doesn’t suit.
Given the new starter is very lightweight by comparison, do I need any rear support for it and will the two main mounting bolts more than suffice?
Cheers Rich
Edited by zambo
  • Solution
Yes you'll be fine without that bracket, you'll need to find a new ground point for the engine but that's not a big deal.
George S Patton
