Crank Pulley ID
bergie33
Go to solution Solved by TobyB,
Can anyone help me ID this crank pulley?  It was pulled from the engine of a 75 2002.  I'm not sure it it is for a car with AC, or if the extra groove is for a smog pump?  I did a bit of searching and didn't find a definitive answer.  I don't need it for my tii, so I'm selling it and want to know exactly what I'm selling.
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
  • Solution
Well, you can measure the ID, of course...  whut, 24mm?  😛
There are a number of threads on this-
what you got there is one version of the A/C, air pump and water pump pulley.
There are several versions of THIS one, several A/C and water pump, several air pump and water pump,
and at least 3 of the water pump only version.
Yup, it's kinda like they made all sorts of options.  Just like BMW.
I DON'T think it's an E21 pulley, as those were 'usually' stamped steel...
Same as this one.  Diameter of some fan pulley sheaves vary.  TDC marks can be in different locations to suit the case pointer location.  The one shown is a case on a 9-71 02 engine where the pointer is at about 5 o'clock.  Keyway is up and in-line with cylinders when at TDC.
