Preventing fuel from draining back into the tank
flagoworld
My thoughts were directed more at Ryan's situation than yours.  Sorry for not making that clear.
I have read many times that these pumps like to push, not pull.
That is why they suggest putting the filter after the pump, not before.
These valves are a restriction in the line and they complicate what would ideally be a very simple situation.
They also add two more hose clamp connections, which can potentially leak.
Perhaps check valves are an okay bandaid for a pump with a bad valve, unless they lead to starvation issues... which could have to do with the capabilities of your particular pump.
I wonder if this is why I have never seen the factory check valve?
It might have been routinely discarded when BMW serviced the car until they stopped fitting them. Alternatively, maybe they were available for dealers to add to bad hot starters in an attempt to do something- so they were added after manufacture.
rtheriaque wrote:
I haven't considered this vacuum issue with blocking the return line.  I recently clogged mine and have noticed maybe a little more difficulty in starting if I haven't driven in a while.  I did not realize the factory suggested check valves.  I will definitely consider this.
