No air bypass screw on early Weber 40's
Throwing in the towel. One carb is untunable on one side of it. Gonna either try to find another old Weber DCOE2 or proceed finishing my parts round up on turbo setup. Have everything but still need to make the plenum and runners and order forged pistons to bring compression down.
My question is can I put the normal intake with 38/38 Weber on and leave the sidedraft coolant bypass kit on and not connect original coolant lines to said manifold? Again live in a hot environment so choke is irrelevant mostly. Does the coolant inside play some sort of role in atomization or..?
Edited by Sharktrainer
No change when I turn that fuel screw like the other 3. Spitting and backfiring out that mouth and exhaust on low circuit. Runs like a raped ape when you get past low rpm issues.
One of the mounting eyes was broken off on this area and broke right along where fuel screw goes. I repaired with JB Weld and it held but this is the area that can't be dialed in. Pretty sure I didn't plug the passage. When I crank it out crazy amount of turns, it shoots a flash of flame.
I've changed for obvious no reason after the fact the idle jets to 55f8 from a 55f2 and air corrector to 175 from a 200. Regulator set to 3.5.
Well there's your problem... That's a pretty big variable you introduced to us! :) I vote Recycle bin. DCOE's are great things when set up properly, I've found. But little inconsistencies like # of progression holes and spacing, clogged passages, dirty jets, etc can lead to frustrating issues if you're just learning, let alone trying to tune out a crack extending into the idle/progression circuit passages.
Quote
My question is
  • can I put the normal intake with 38/38 Weber on and leave the sidedraft coolant bypass kit on and not connect original coolant lines to said manifold?
  • Does the coolant inside play some sort of role in atomization.?
Yes.  It'll work
Yes, it improves fuel vaporization by preventing fuel from condensing on the walls of the manifold.
Keep your busted carb as a parts carb, and hit ePay or such.  Single bodies do turn up from time to time.
See?  You CAN sometimes go wrong with JB Weld!  Glad you got it sorted, tho, and thanks for the followup!
Should have used duct tape.
Today my jets, emulsion and correctors finally arrived.
Ordered;
190 corrector
F16 emulsion
120 main
50F8 idle
Prior
170 corrector
F15 emulsion
125 main
55F2 idle
This is how I came up with the supposedly correct jetting (some random Weber site)
With the prior jetting, I was getting maybe 4-6 miles per gallon, but it had big kahunas.
Installed the ordered jetting and it runs smoother, economy probably 12-15 miles per gallon, but it's not quite the savage as with old jetting. Notice it starts leaning out @4500 rpm whereas the old jetting didn't struggle when you pushed to redline, in fact got there in quite a hurry.
My question is which component should I change to maintain fuel economy, even 10 mpg is fine just as long as it has stab at upper rpm range.
My thought maybe one step on main jet? Go back to F15?
Or should I leave as be and turn the screws in some more?
Check your float levels a third time- a 120 main jet should get you over 12 mpg at the race track.
But what kills your fuel economy is the 'idle' jet, which is really a transition jet, and is doing most of
the fuelling when you're cruising below about 80 mph.
So try going smaller there, and you'll find you have to open the idle screw to compensate, at a certain point.
But you'll get notably better economy.
at 5 mpg, you're probably dumping raw fuel- which isn't good for anything.
I agree, the wideband is such an indispensable tool for Webers, I wouldn't go out to the garage without one.
