Fuel Pump Oil Pressure Switch
I tried searching, but have been unable to come up with the right string of words to find threads about this.
I want to wire my fuel pump to shut off if the motor stalls (safety in case of an accident)
Would I need an oil pressure sensor with two prongs in order to make this work?  Is there a kit anyone recommends?  Right now I just have a fused wire off of ignition power going to the fuel pump.  -- Seems like the wrong way to do it.
Thanks,
   George
Look at Pegasus Racing and search for "fuel pump shut off switch ( oil pressure). Just remember you will need a manual override switch to fill the carb(s) before you can start the engine or pressurize the fuel system if you are running FI.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
I installed an inertia cut off switch from Pegasus in my 69, along with the Carter rotary electric pump from Ireland.  In-line fuse runs from the battery (below the back seat) into the trunk to power the fuel pump relay.
0309CD8E-D22D-4086-8E47-BFAEED310F0F_zps
AF1AF980-2313-4FCE-97B4-0EFEA8F3761E_zps
