IE Cast Pistons. Advice Please.
1.  Not really.  Get 4 pistons that are all the same size, then bore one diameter to fit all of them.  This is not 1917...
2.  As above, Call Jeff.  Jeff Ireland.  The guy that Ireland Engineering is named after.  He may be cranky about it at first, but he will give you the right answer.  Because if he doesn't, he won't sell pistons.
Because I own a set of these pistons for an upcoming rebuild I contacted IE and was told it is best to bore each cylinder for each piston to insure you get the proper cylinder clearance
The cylinder clearance by the way is the same as stock , From my research then cylinder clearance should be 1.6 thousands of an inch.  I'm decimally challenged, but I think that is 0.0016
