Help with longer wheel studs
Neildo11
I'm looking for longer rear wheel studs to fit my bbs mahle wheels that have a thicker hub mount surface. I've read many threads regarding longer studs but nothing I could find meets my needs. I know IE has 70mm studs but that's overkill and i'd also have to get open lug nuts to deal with the extra length.
Ideal length is 58mm, the closest I found is a dorman 55mm stud but the knurle is 14.20 not bmw 14.40. Thoughts on whether or not .20mm is going to be a problem?
If anyone knows of a stud that fits an 02 rear hub (12mm-1.50, 14.40mm knurle) in my desired length, I'd appreciate the help.
- Neil
74 sahara M42
Part # 33.41.1.106.765 is still available - approx $9 each ($144 per set of 16)
IE's are only $5.50 each ($88 per set of 16) - time to break out the grinder and save $56
Beaner7102
  • 1 year later...
