5 Speed Release Bearing
zooz3
I believe it is different depending on which flywheel you have. do a search and know which flywheel you have, it will either be the 320 or longer 323 throwout bearing.
The 215mm clutch can use the standard 320i bearing, if you have a 228mm clutch then you need the longer 323i bearing
I am not sure these part #'s are current but this is what I have in my notes:
320i bearing:  21 51 7 521 471
323i bearing:  21 51 1 204 525
HTH
Lane
Edited by FunkyLaneO
74 Golf
