Closing Door Mechanism
70deluxe
I'm taking my door handles and trim in to get repolished before I repaint my car.  I took the door handles off and then out of curiosity (don't ask me why I did this) I grabbed the piece (no idea what it's called) in the first attachment and turned it clockwise.  As I did this I heard two clicks.  Now I can't get it to go back to original setting so I can close the door.  It just collides with its counterpart on the door frame.  I reached my hand inside the door (the door panel is off) thinking there'd be some simple piece to unlatch or click, but I can't find anything.  Can anybody offer a major rookie some insight on how to unlock this piece so I can close the door again...?
post-45038-0-66488600-1375897169_thumb.j
post-45038-0-04273100-1375897181_thumb.j
post-45038-0-99998200-1375897188_thumb.j
did you try pushing down the part of the "U" shaped thing? the part without the plastic sleeve on it.
Or did you squeeze the door handle?
Edited by BillWilliams
1972 2000tii Touring #3422489
FAQ member #5
Hi,
  so now that the door handle is off the internal
bits do still work. look in the hole where the handle
was and lift up the visible square in the door. now
push that part in just like the handle does when
installed. the u shape catch should spring to the
open position. if the spring for the catch does not
work or the mechanism  is dirty and stuck you
can push in the metal square and rotate the u shape
to the open condition.
good luck
stone
stone racing co
phila pa 19123
