So the rebuild is almost done and i am told the car starts fine... But after a few minutes of idle it starts to sputter and die. The gas tank is not empty. I am told the rebuilt warmup regulator has been adjusted.
So close. I am going to read my kf manual and the restoration guide tonight to see if i can lend inspiration.
1973 2002Tii (Pacific Blue)
1984 911 3.2 Carrera (Platnum Metallic)
2009 328xi (Black Sapphire Metallic)
2010 Mazda Speed3 (Black Metallic)
I think you need to consider this. If the car idles for a few minutes, it is running under the control of the warm-up regulator and that is great! However, if is dies after the warm-up regulator gets out of the equation (the top hat washer clears the lever), then you need to chase other things.
Idle speed - the small screw with locking nut that goes through the tuna can
Linkages - all the correct length
Linkages - adjusted correctly especially at the intermediate shaft
And all things Uncle CD - timing, valve adjustment, etc.
1972 2000tii Touring #3422489
FAQ member #5
We think linkages are the culprit. Some manufacturing was done but to what level i am unsure. I think idle was adjusted but i will mention it
Update: second hand info, but he has adjusted idle and valves and all of that and linkages were spec. He plans to reverify linkage tolerances in case something came loose.
Edited by gliding_serpent
