74 2002engie cuts when cold
tloguzzo
Have a problem with my 1974 2002
When I first start engine cuts out
Ignition system is the problem believe ther is a relay or something
Acts like a thermostat as engine warms up the problem goes away
I installed a bypass wire from battery car act normal
Remove wire problem returns
What am I missing just install 32weber choke working perfect
1. What kind of choke is installed on the weber?
2. Will it studder then die when cold? This is pretty normal... you may need to adjust your choke. With my electric choke on my weber I need to hold throttle open a little until warm. Nothing out of the ordinary, it's an older car and requires a little more manual input.
3. The ignition system (disregarding the starter) has no relays.
4. If it is an ignition problem, then it won't idle when warm either.
5. Has standard maintenance been done by a reputable mechanic? This includes adjusting timing, idle/mixture adjustment on carb, points replaced and gapped properly, points, condensor, wires, and coil are in good condition, valves adjusted to spec.
6. Do you have the EGR equipment hooked up?
7. Did you check for vacuum leaks?
We need some more information.
EDIT: What wire are you talking about that you "bypass"
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
Check your Fuse box. Don't recall the number of which one.
That wire is hot all the time with the key on.
If I understand and can translate- the power to the electric choke is not supplying power. The choke appears to be working when jumped from the battery.
Houston, TX
