C.D., Tom Jones... Can we talk Turbo..??
02for2
Hey guys,
There's a local guy here who owns a Turbo (presumably Factory Stock) and contacted Steve (aka Blunt), about helping him get his car started. Steve subsequently contacted our group to see if anyone could go look it over and possibly lend a hand.
In emails w/ the owner, a possible 'tell' is that he says the Fuel Pump no longer makes a 'whirring' sound when he turns the key. We'll check the pump, grounds, fuse, drop-out relay (if so equipped).
My intent is to go over and make sure the car is within spec - Timing, Plugs, Advance, possibly valve lash, check fuel pressure... the basic Fuel Air Spark diagnostics.
Problem is, my manuals do not have any of the Turbo specs.
Do you guys, or anyone else for that matter, know what these are? Timing, Advance, Spark Gap, Fuel pressure, Valve Lash...??
Thanks in advance... and I'll be sure to post some pics !!
Cheers!
1976 BMW 2002
1990 BMW 325is (newest addition)
1990 Porsche 964 C4 Cabriolet
no drop out sw. for the pump - pump just runns and runns with the
the key "ON"
disconnect the main fuel filter hose at the radiator and get a sample
of gas into a clear bottle - 30 sec's should give about 1 liter
T in a fuel pressure hose to the cold start injector = 30 psi
remove plastic cover for the front Kugelfischer
drive cog belt - this is one of the top 3 things to look at first
compression test
ck valves - inspect condition of valve/cam/rocker area for nastyness
for starting it doesn't matter that it's a 2002 turbo,
-all the basics matter. COMPRESSION, IGNITION, FUEL PRESSURE
HAPPY TURBO HUNTING!
'64 R27 250cc #383851 18,000m
Fuel Pressure is the same as a Tii 28 PSI
Throttle linkage set up is the same as a Tii, use the same special tools (hooked tool in the linkage/pump body at the pump, Pin in the throttle housing and the special jig to set the linkage rod length )
Timing is set at 25 deg BTDC @ 2500 rpm (the ball on the flywheel with the engine at 2500)
Plug gap 0.024"
Valve Lash same as all 2002's 0.006-0.008"
Cold start injector system is exactly the same as a Tii
Cold start enrichment at the pump and mixture adj for the Turbo is unique to the turbo and you should not have to play with it just to get it started.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
