1976 02 A DYING PROBLEM
ramayah
Hello,
My car runs and then dies. It will start up fine but when on the road for a few minutes it will just die. This happens as I try to accelerate. As soon as I step on the gas it will rev up and then cuts off. After a few moments it will start again, run for another minute or so and dies. If I keep driving at 20MPH it will go a bit longer but the moment I step on the gas it just goes dead.
The fuel pump pumps gas to the carb just fine. The carb seems to be getting gas. After reaching home from the short drive and I parked, now it wouln't start. I believe I might have flooded it.The carb is 32/36 Weber.
Your help will be appreciated. Thanks
Randy
that's been discussed recently in a few posts, with lots of insight, so a search would be helpful to find all the discussions.
One problem noted: a crap-filled pickup tube in the gas tank. Gas percolates through a little bit and can make a quick static test look OK. But the restriction prevents the full flow needed for full running.
Carl
clogged tank pickup
porous cloth fuel hoses - sucking air
crushed or bent hose/pipe someplace
tired diaphram in mechanical fuel pump - replace the pump
carb float incorrect - too low
problem with float needle and seat
really dirty carb and all the jets and tiny passages
it's not your ignition.
I believe the problem is solved.
I tried to start it this morning and it failed to fire up. I then checked the plugs for spark and had none. I checked the points and the gap was almost closed at its wide opening. I beleived I was not getting a spark. I then filed the points and regapped it to .16 and cleaned the cap. At first turn of the key it fired right up. Took it for a drive and and it didn't die upon hard acceleration.I am very happy now.
Thanks everyone for all your suggestions. I appreciate it.
Randy
