euro front turn signals
mikea
I just bought a set of NOS Euro front turn signals
the bulb terminal seems to only have 1 wire
whereas the old one of course have two
for turn signal/4 way flasher & for running lights
do the Euro turn signals not have running lights?
any info appreciated
Nope. Euros only function as turn signals. There are several ways to incorporate turn signals into the euros, one being the use of Tap-A-Lites.
http://www.uhaul.com/MovingSupplies/Wiring-lights/Adapters/Tap-A-Lite?id=3286
Edit:
Earl has an alternative method here:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,268960/highlight,euro+turn+signals/
HarryPR
BMWCCA #19290
Go with the non-drilling methods. Much easier. I added a simple LED side light from O'Reilys and used two tie wraps to secure it to the the bar. Ground it at the mounting screw. Done.
Mike
76 Malaga (Molly)
Mods:
Weber
Recaro
Eibach
Bilstein
Panasport
Ansi
Parker
Ireland Eng.
'72 Tii Project
WHEN I INSTALLED THE EURO LIGHTS , I USED A PAIR OF USA LIGHTS AND SWAPPED THE GUTS .
THEY ARE HELD TOGETHER WITH HOLLOW RIVETS SO I MADE SOME
NEW ONES FROM BRASS ON A LATHE .
THEY MUST BE CONDUCTIVE BECAUSE THE UNIT GROUNDS THROUGH THE
MOUNTING SCREWS .
IT WORKED GREAT AND HAS ALL BMW PARTS ( EXCEPT FOR THE RIVETS )
