brake pedal sticking !
What the heck
Stays part way down only some times Where do I start looking ?? Can be a surprize as I pull into Dutch trafic
3421912 ask john
Red Baron a 74 sedanw/ dual webers ,spring,steins,bars. body shop for a full make over
Red Baroness a 71 1600 touring new to me and on the street in Limburg
Old Reliable a 93 318 m42's are soooo cool
check all the linkage bolts before anything. I spent a ridiculous amount of time trying to figure out why mine was sticking and it ended up being the upper linkage pivot(right before the brake booster). It had corroded just a bit and caused the linkage to bind, loosened the bolt 1/4 turn and it solved the problem. Also make sure your return spring is still in place in the pedal box.
If that doesn't work then try bleeding the brakes, if it's still happening then you probably need a new mater cylinder.
your supposed to put a few drops of oil on every pedal piviot,
gas pedal/carb linkage, door hinges/strikers, hood/trunk latches, check steering gear oil level at every oil/filter change
get after it
'64 R27 250cc #383851 18,000m
  • 6 years later...
