Handbrake is loose
mine does the same thing. I pulled up the boot and it didn't seem like anything was broke, so I didn't fix it. When the brake is on there's no wobble.
If you look closely, you'll find that the ears welded to the body have worn holes in 'em and the pin that passes thru the brake handle is sloppy in these holes. You might take the pin to a hardware store and see if you can find some bronze shoulder bushings that can be pressed into the sloppy holes. You might also find the hole in the brake lever itself is worn. If that's the case, find another handle or press bushings into it too.
Mine have been loose for years; I just live with it! When it breaks, I'll fix it.
Cheers
Mike
Nevada '69
Sahara '73
  • 21 years later...
6 hours ago, C.Flint said:
My handbrake responded well to this simple fix...
Yes, but we didn't have that kit available 22 years ago!
  • Haha 2
John in VA
worked for me also, but I duplicated the function with (gasp) SAE inch parts of similar dimensions.  There are also a few posts about it, with someone offering a kit of parts on the FAQ some years back.  IIRC, the key parts are the little very thin thrust bearings and washers that go on either side of the lever in between the sheet metal mounts, filling the gap and allowing you to apply a wee bit of tension to take up the slop.  The trick is to get it all assembled without loosing bits to the ground below.  Extra hands and a few bits of tape help.
