EGR, Clean/Repair or Remove?
asifallasleep
Can i clean/repair the EGR?, is it still sold new?, or should i remove the whole system? cost of removal? i really believe it's malfunctioning and causing all my issues.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2000 Porsche Boxster
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
I'm not an expert, but I believe if you remove the first thing labled "what's this" you'll have more problems than you think (mechanical fuel pump)
68' 2002, GRANADA RED
88' 325es, RED (previous car)
77' 320i, SIERRA BEIGE (previous car)
www.68roundie.blogspot.com
LOL, Oh i that what that is? i wasn't suggesting the removal of that item, but all the EGR/Emissions components.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
no EGR in this photo - arrow indication "egr?" is really a fuel return valve.
and the "whats this?" arrow is pointing to a mechanical
fuel pump
the above photo is good because it shows no tangle of hoses,
and plumbing from Air Pump, EGR emission control parts.
no EGR there
and NO - you cannot revive an EGR valve -
hot corrosive gases pass through it eating out the innards
which would cause a leaking valve when it should
be closed and sealed. When a EGR valve 'leaks' internally,
you have a lousy idle, to no running at all, and major loss of power during acceleration
fuel pump
no EGR there
wow thanks so much. i need a diagram to figure out what my engine components are.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
dont take all CD's words for granted...i refurbished the complete EGR system on my Automatic 02 and is TOTALY doable, i did it just for the sake of going against everyones argumentation, but i ended up blocking the egr flow OFF since even when 100% new it is a bit on the edge.
http://www.dagsites.com/emissions.htm
1985 XR4TI, 22psi ±300hp
remove the EGR unit and clean the passageway with spray solvent. Then test for valve actuation with a hand operated vacuum pump. If it has stage one and stage two pull on both vacuum ports. Watch for valve action ... the piston in the bottom moves. If the valve is jammed or if the diaphram leaks you have to toss it and get another one. Unfortunately new ones are pricy but there are used ones that can be cleaned and put into service.
the thing you've labelled 'egr' is actually the idle fuel bypass valve.
If it's working right, it does a good job of reducing flooding at hot idle.
